Washers/Bushings
Washers/Bushings
Washers/Bushings
Hi All:
I have steel axle(shaft)in aluminum part, and I doubt  eventually corrosion might take place due dissimilar metals.SO in order to aviod this I am planning to use bushing to reduce corrsion but I am worried about that busing being soft material may not take the load and might fail to transfer the load.
Please any thoughts on this would be appreciated.
thanks
RE: Washers/Bushings
Uhm?
Select the bushing material and size appropriately for the load.
Not sure, of your exact arrangement but.... as long as you treat one of the surfaces, say the aluminum via anodize then you shouldn't have a dissimilar metals issue.
Can you post some more specifics to the design?  One suggesting is using a metal backed bushing like these http://www.afmusa.com/bushings.metalbacked.asp
Heckler   americanflag
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
      o
  _`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
Make the bushing out of steel and have it cadmium plated.
