Hip Roof - Wood Frame Construction - Typical Residence
For a hip roof, with hip beam meeting a non-structural ridge with collar ties, is there a need for a post to support the hip / ridge connection point, or will the vertical load go thru the hip beam to the exterior stud walls.
RE: Hip Roof - Wood Frame Construction - Typical Residence
So, with small collar ties, you probably will not need a king post to support the hip, but will probably need a beefed-up collar tie at the attachment of the hip.
Mike McCann
McCann Engineering
Collar ties will add flexure to the roof joists. The hip arrangement brings more load to select joists than a plain gabled endwall. Depending on the system's stiffness, you might need to consider the horizontal thrust on the sidewalls.
Mike McCann
McCann Engineering
