custom file new in Nx5
I want to redirect the file new (template) folder for our company needs. Is there a variable / I found nothing in the docs.
thx in ad
RE: custom file new in Nx5
As far as I know templates are called from a .pax file, so that the files used are addressed according to a specific directory path and filename. Have a look at the palletes settings and then open your .pax files with a text editor and you should see what I mean.
A common use for templates is for drawing formats and to do that you may use patterns. The directory where patterns are kept is set according to and environment variable.
Best Regards
Hudson
thank you Hudson,
I know / I looked how it works / tested several things.
The filename tag in the *.pax file.
Can I redirect to Pax file located in an other folder...
change the from ugs tepmlate pax file to my own in the file new dialog.
thx in ad
If you've established a UGII_USER_DIR folder, place your .pax file in the 'Startup' folder at that location and it will replace the system's default .pax file.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Hudson, John,
How to redirect 3D Master model template?
My customer demand that all jobs have to be provided on his seed parts.
I would like to call to my(or my customer) templates from;
1) File==>New,
2) Assemblies==>Components==>Create New
3) or Wave==>Create linked part.
How to do in native mode (not under TcEng). It is possible? (GTAC claimed that it is possible only under TcEng)
I know how to call drawing templates and modeling templates from palletes but it not works when I need create part according to point 2,3.
Siwy
uwam2ie,
I may be misunderstanding your questions, but just to make sure we're on the same page, what you do is to copy the .pax file to any directory of your choice, I have edited several versions for different customers. Then you go into Perferences>Palletes and you add or remove palletes of your choosing from there, by browsing to the directory where you saved different .pax files. NX remembers your palletes for next time based on whatever you last had opened.
Whether you can swap between customers using roles or not is a different prospect that I'm yet to dabble in.
What you could do is to launch NX using a batch file so that if you have a file called "metric_drawing_templates.pax" that contains your drawing formats for customer A, and then you create another file of the same name in a different directory for customer B, then you could replace the file on disk with a saved copy from elsewhere depending on which customer environment you want to work with.
There are probably other ways to achieve this. As I said I'm not sure I'm on the right track, but let us know if it helps.
Best Regards
Hudson
Siwy,
In native if I understand your question correctly what you want to do is to create a master file to that all files that you open will be uniformly set to your particular site standards. As I understand it people like to set up model templates and perhaps they more or less have a list of the, for different customers. The reason that this has limited effectiveness is that the creation of new parts can draw on files from more than one place. What you need to do is to set all your customer defaults to site setting and then use files based on those setting to create all your template files for models and drawings.
You probably also want to create empty inch and metric files to replace the translator "null" files. To find these do a search for *null*.prt in the UG install directory.
The Best way to support different customers in native that I have seen used is to set up different customer defaults, templates and even you translator "null" files for each different customer and then create a batch job to launch NX separately calling the defaults for each different customer. There have recently been detailed posts with a range of opinions about how to best do this. A search of the Forum topics ought to able to help you find that information.
Best regards
Hudson
Thank you John, Hudson for answer.
Hudson,
I set up diffrent directories for each customer (eg difrent env files, custom symbols etc) and UG relase (I had problem with menu files NX2& NX4, users have own folder with saved menu files UGII_DEFAULT_MENU_DIR). UG is run by batch files.
Siwy
Ok, thank you John, works,
but the Nx pax from the UGII installation
are shown, too. Is there away to turn the standard templates from UGII off without deleting them.
thx in ad
JOHN;
I had copied the files from the ugii/template dir to the startup folder of the UGII_USER_DIR ( same filenames different folder). The result was that I had two tabs for modeling and drawing one was connected to the orginal in UGII dir the other from the new location...
what did I wrong?
thx in ad
Poor solution :(
 // no workaround without touching the orginals?
thx in ad
You could move the originals to a different location, or rename them.
Believe it if you need it or leave it if you dare. - Robert Hunter
I found a solution // as I understand...
I set up UGII_TEMPLATE_DIR to somewhere, this overides the default location in \\ugii\templates
