UNDERGROUND OXYGEN LINE
COULD ANYONE GIVE ME ANY INFORMATION ABOUT THE DESIGN OF UNDERGROUND PIPELINE CONTAINING OXYGEN USED FOR WELDING IN A SHIPYARD. Q=1000 M3/H.
OP. PRESSURE = 15 BAR.
WHAT KIND OF A MATERIAL TO USE. CAN CARBON STEEL PIPE BE USED.
IS THERE ANY THRUST BLOCK NEEDED.
PIPELINE IS ABOUT 10 KM.
THANKS IN ADVANCE
SALIBA
THANKS IN ADVANCE
SALIBA
RE: UNDERGROUND OXYGEN LINE
AIGA 005 fire hazards of oxygen enriched atmospheres
AIGA 012 cleaning of equipment for oxygen service
EIGA doc 13 oxygen pipeline systems (CGA G 4.4)
EIGA doc 33 Cleaning for oxygen
EIGA oxygen safety
EIGA training package
Unfortunately, the customer neither have any specification, nor have any person related to this subject.
the specification of the equipment that shall supply oxygen is as follows. Wea re talking about Oxygen purity: 99.5 % by vol.
Gaseous oxygen (GOX): 1000 Nm³/h, based on oxygen consumption during
12 h/day and 5 – 6 operating days per week
Delivery pressure of gaseous oxygen: 15 bar g
All outputs indicated above refer to normal cubic meters (0 °C, 1013 mbar) and are subject to air compressor suction conditions of 30 °C ambient temperature, 1013 mbar barometric pressure and 70 % relative air humidity. Output parameters are valid with a tolerance of +/- 5 %.
Thanks in advance
