Corrosion monitoring of internally fusion bonded epoxy lined pipes
I need corrosion monitoring transmitters to be used in internally fusion bonded epoxy carbon steel piping systems so as any holiday of the FBE to be noticed and underneath CS corrosion to be caught up and avoided. I understand that the element material is usually the same material with the pipe and that the probe body is a superior material from the element and corrosion resistant to the fluid. Could you please advice for the element material considering also that the equivalent material instead of FBE lined items, e.g. for pipes NPS<2 is UNS S31254. Since probe body has to be a superior material from the element and corrosion resistant to the fluid, UNS S31254 or INCONEL 625 may be selected. What about the material of the element? How can I achieve corrosion monitoring of Internally coated pipes?
RE: Corrosion monitoring of internally fusion bonded epoxy lined pipes
Try to get hold of NACE International Publication 3T199 Techniques For Monitoring Corrosion & Related Parameters In Field Applications and determine exactly why you are measuring, what you want to measure, and what you are going to do with the data.
Steve Jones
http://www.pdo.co.om/pdoweb/
