ASCE 7-05 Wind Uplift All-Heights Load Case 3
This is not a new question. See thread507-178618: Fig 6-9, ASCE 7-02 February '07 and thread507-139345: ASCE-7 Wind Load Cases November '05.
I am in California where we just adopted the ASCE's hurricane region wind code (we only have gentle breezes and its always sunny). Does anyone have a clear understanding of the ASCE 7-05's intent regarding wind uplift and All-Heights Load Case 3 in Figure 6-9. There is a 1.5 times increase in the design load for uplift on interior columns if one interprets the code's "Load Case 3" to mean 0.75*(Longitudinal+Transverse) for uplift (not just lateral loads). In a low rise metal building this translates into big differences in footing size and cost. I found this language being stricken from a code revision proposal on an NCSEA meeting agenda on the IBC "torsional effects resulting from full and partial wind load combinations identified in ASCE 7 Figure 6-9." at http://www.seaot.org/tcc/GES_Agenda_07.pdf
Note the use of "partial" to descibe wind load combinations. Also Figure 6-9 of the ASCE 7 uses the language "Full design wind pressure acting on the projected area perpendicular to each principal axis" , and the notes 1-3 below have no mention of a "z" or vertical axis, only the "x,y" principal axes.
Is this a deliberately vague presentation in the code which is so precise about the values for Cp?
I sent a note to the ASCE wind committee and hope I get a response. Perhaps someone knows where to get an authoritative and clear interpretation of the code's intent even if it is to leave it up to engineering judgement.
Thanks in advance.
Thanks in advance.
