Assembly components in tree
If I change a file name, and open the assembly that that file is contained in, obviously it can't be found.  So then I select the file with its new name and everything should be fine.  However, the assembly tree still shows the component's name as the old file name.  I can manually change it by changing the properties, but I want it to be automatic.  Is this a setting somewhere?  I've looked but can't find anything.
RE: Assembly components in tree
ctrl-Q
That was the first thing I tried, it doesn't do it
Try using SW Explorer to rename files and replace references.  Also try usng RMB --> replace component to swap components (before you delete the old).
RMB the component in the assy tree, Replace Components, find the newly renamed components.  Read up in SW Help for "replace" for further info.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
But I'm not replacing, I'm renaming a component.  Making a new file, then replacing the old one with the new one, and then deleting the old one just seems like a waste of time.
Tools->Options, System Options tab, External References category, Assemblies group, check box for "Update component names when documents are replaced"
Yep, that was it. Thanks handleman
No prob... just found it myself a couple months back.  thumbsup
