Used column calculating theoretical plates
Hi
I am looking on the second hand market for a new distillation column to replace a bubble cap 12m height 34 actual plates 20 theoretical.
I am looking for something better, possibly packed. When looking on the second hand market, they never list theoretical plates, how can I calculate this from what data they do give/what data do I need?
RE: Used column calculating theoretical plates
Your existing tower has an overall efficiency of approx. 60% (divide No. of theoretical plates with the No. of actual trays) and this can serve you as a guidance number for rating columns in the market (actual trays X efficiency) - if operating conditions of the tower are more or less the same. Anyway, I'd strogly suggest not to do this tower rating estimation job by yourself; ask for assistance from vendor/consulting companies. I would do it that way.
Best of luck,
http://antwrp.gsfc.nasa.gov/apod/astropix.html
So how do I know it is X times better than the current one (which is not hard when current one is rusting away and bubble caps all blocked)?
Contact packing supplyers for there info?
But, if your existing tower is experiencing severe fouling and corrosion you are maybe looking for culprits in the wrong direction. I don't believe bubble-cap design is the cause of column malfunctioning and chances that internals replacement will solve the problem are very small. This is just based on my experience, I don't know the full story here.
