EN 12567 (2000) Type tests for on-off LNG valves
       The European Standard in object defines the requirements and the "appropriate verification tests" applicable to "insulation valves for LNG".
       Has anyone ever faced the requirements of this standard?
       Has anyone ever executed one of the type tests described in its Annex A or Annex B ?
       Does anybody know about laboratories performing such tests?
       After a quick search on the web, the only interesting reference I found is the following, 'till now:    http://www.chemicals-technology.com/contractors/valves/herose/herose4.html
       Other discussions about similar or related issues may be found, within this Forum, at:
               -     thread408-148535: Alternative to BS 6364 for cryo-testing?  and  thread774-127182: Cryogenic Test Bench for Valves     (about cryogenic testing)
           and
               -     thread408-114236: Institutes/laboratoria for valve testing  and  thread408-163274: Ext. Lab's for valve FIRE testing (in ITALY or near)     (about Laboratories).
Thanks in advance for Your kind contribution,                 'NGL
