Small wind turbine mast design tips
I have to do a simple stress analysis for mast of a small wind turbine (3 blades, rotor diameter 4m).
For normal cases, almost anything would go, but in this case, the mast has to be longer (20m) to get the machine well above forest line.
Any recommendatios for the allowable deformation due to aerodynamic load, or for minimum eigenmodes in bending/torsion, please?
RE: Small wind turbine mast design tips
