How to undo under Hypermesh ?
Hi everybody,
I hope that some one know how to undo modification after exiting any feature (namely, when i click on "return")rather than using "reject". it is so annoying to re-open ,every time when "reject" doesn't work, the application to restore initial state!!.
Thank you a lot.
RE: How to undo under Hypermesh ?
<rant> there must be some sort of unix based conspiracy that says that Undo is a bad feature</rant>
Beats me. How to halve your marketshare. Wise up, codeboys.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
