steam calculation/advise
Possible to estimate how many BTU's it should take (I've only got about 25000) for a gas burner to generate enough steam to blow about 20 GPM water (flooded suction, almost zero lift) with one or two eductors/ejectors?
If so, what size pipe and jets should I order?
Thanks... I run machine tools better than "slide rules"
RE: steam calculation/advise
If you only have 25,000 BTU/hr then you might be better off with using water as the motive fluid or just a regular pump.
StoneCold
