Bonding Mazak casting?
Hi Guys,
I have a small screw in fitting that makes an oil return outlet for an rotrex supercharger. My issue is that i need to change the angle of the outlet due to clearance, I have cut and made the changes required to the angle and now have the issue of bonding the 2 peices back together again. Any help on a product would be greatly appreicated.
Darren
Darren
RE: Bonding Mazak casting?
Are you looking for a suitable structural adhesive?
http://www.welding-advisers.com/
ht
http://ww
http://www.loctite.com/int_henkel/loctite_us/
