Low Temp PSV's
Low Temp PSV's
Low Temp PSV's
I have a need for Low Temp PSV's in a short amount of time 4 weeks.  Can anyone suggest a supplier who can handle a delivery in 3-4 weeks in body material LCC LCB or LF2 ?  Sizes vary and I can change, upgrade specs to procure delivery needs so I will not be specific here. However the bodies need to be of the materials mentioned above.
RE: Low Temp PSV's
just the facts. Size, temp, pressure, rate, fluid properties.....
RE: Low Temp PSV's
I just bought a bunch of Farris valves (conventional spring type) on a three week ARO ship date. Some of these were austenitic stainless.
Most of the big name relief valve makers can expedite orders, but you will have to pay extra.
RE: Low Temp PSV's
Without facts, here are some problems.  We had a 2280 psi relief valve and the material auto refrigerated to -150F.  The relief valve manufacturers couldn't get us a 2"x3" valve with the correct combination of spring force and metalurgy for the temperature.
RE: Low Temp PSV's
rolyatyerttt needs PSV on urgent basis. First criteria for him is availability. After identification of supplier with ex-stock, then rolyatyerttt will further provides the technical information for further evaulation.
RE: Low Temp PSV's
I suggest you call all your suppliers/vendors and see what they have.
How about stainless? They are often used in low temp sour applications - bit more costly though.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
