WOOD RETAINING WALL DESIGN
Can anyone direct me to design aids for wood retaining walls? Charts/software etc.? I am designing an 8' high wall with no-slope or surcharge behind. I will replace clay soils behind with drainable bankrun or the like...
Thank you ...
Thank you ...
RE: WOOD RETAINING WALL DESIGN
http://w
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
An excellent link BUT when I tried to print it out I got unintelligible garble. Is this Australian publication perhaps coded in some way that makes it un printable on U.S. based computers ? Should I copy and paste it into Adobe Reader perhaps ?
still, it was worth the star.
I'll bet my K&E Log Log Decitrig to your Picket Pocket Model that i can find some use for it when global warming takes full effect though.
Sone PDFs composed using Wordperfect fonts do not print correctly if you don't have them on your computer.
Try the following link to download some of the more common WP fonts.
http://www.geocities.com/jtdonville/wpfonts.zip
Hope this helps.
Jeff
It is suggested that they fail NOT because little is known or published about how to design them but rather because:
Wood is a natural material with widely varied properties
Not all important properties can be predicted
These properties change with time and loading
wood can be attacked by insects, water, weather, plants (tree roots for example), chemicals, rot, and burrowing animals
good quality, durable heart grade wood is expensive and hard to find
walls are often subject to overloads, such as heavy equipment, which were not anticipated in the design
