Another pier question
Is there a guideline for the aspect ratio of a pier?  For example, if I have a 30" diamater pier, how long can it be and still be effective?  Thank you.
RE: Another pier question
I don't think there is a "rule of thumb" for pier/pile design. All the dimensions (dia, length) are tied to the soil characteristics and types of loadings.
Some of the recommended unit end bearing values for piers (particulary those presented in the ensoft program "Shaft") are based on a minimum embeddment of 10 pier diameters.  So for shorter embeddments, you would need to recalc.
There is a fact sheet from an early (01 July 1997) publication by USACE (EI 02C097) page 1-12 which consolidated some ratios.
The IBC now defines "piles" as elements that have length/diameter ratios larger than 12.
Piers are those with length/diameter ratios of eqaual to or less than 12.
(see chapter 18)
Piles use skin friction primarily.
Piers use end bearing and/or skin friction.
Although many piles that terminate in soil are refered to as friction piles, they often depend on bearing for a significant portion of the load.
