Concrete Spalling after welding at steel connection plate
We have a new project where a concrete wall shows spalling right after the end of a steel beam was welded to a steel plate that was attached to the vertical face of the wall. Have someone experience such a problem? or was something to do with the Contractor's installation procedure that cause this spalling?
RE: Concrete Spalling after welding at steel connection plate
