Hole position in Circular member/tube
How does one position/place a hole on a circular face, for example a locking screw hole in a shaft collar or a penetration thru the side wall of a pipe.
I have done a keyword search to no avail.
Thank you in anticipation
RE: Hole position in Circular member/tube
Highlight say the YZ plane and click the new workplane icon. Drag the new workplane to outside the cylinder Start a new sketch on that workplate and drill back through the cylinder
Ross
