What is the internal radius of a counterbore?
I've recently been asked to justify why we do not call out the internal radius at the bottom of a counterbore. Generally, we call out the thru hole diameter, the diameter of the counterbore and the depth of the counterbore with no mention of the radius allowed. Is there a standard for this? I've searched and can not find one. I have never seen a radius callout with a counterbore, but I think it is a fair question.
Thanks for any help!
RE: What is the internal radius of a counterbore?
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
As the corner on the c'bore would otherwise be a sharp edge I'd say this applies. However, I doubt most tolerance analysis we do take this into account.
I thought I'd seen a suggested or typical value somewhere, may have been in Machineries.
KENAT, probably the least qualified checker you'll ever meet...
Why do you have to justify not doing it? Shouldn't they justify why it should be done if they are the ones that want it implemented?
Powerhound, GDTP T-0419
Production Supervisor
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Yes, I am referring to where the wall of the CB diameter meets the floor of the CB. I've never seen a radius specified for this, but it sounds like it is needed. I need to justify it because someone noticed it isn't dimensioned and therefore the drawing is incomplete unless I can argue otherwise.
Chris
AutoCAD 06
ctopher's blog
Chris
AutoCAD 06
ctopher's blog
However, I do not find this necessary and I have always included a note like the one KENAT gave or perhaps use this "Unless otherwise specified, all tooling radii to be MAX R___."
One way or another however, I do specify or cover it.
