AL 6061-T6 vs AL 6061-T651 Sheet and plate
This question was posted Jan 2005 with mixed and indefinite results, so I am asking again.
Is the difference strictly thickness cutoff i.e.> .5" (13mm) or is it the solution heat treat and stretching process that defines which is which?
I am not asking about T6511, since it is (I believe) tube or extruded shapes.
RE: AL 6061-T6 vs AL 6061-T651 Sheet and plate
