220 VAC 60Hz two phase VS 220 VAC 50Hz single phase
I am trying to clarify if a 220 device can be attached to either a 220 VAC 60Hz two phase (USA) or 220 VAC 50Hz single phase (Europeon).
1) Are there any cautions or dangers?
2) Can you go one way and not the other?
3) Are there guidelines for testing devices to verify they will work on both systems?
4) Are there any articles addressing this?
RE: 220 VAC 60Hz two phase VS 220 VAC 50Hz single phase
Julian
