Pressure Test for a Control Valve Repair Body
What is the code applicable for pressure test of a control valve repair body? I was rewiewing the B16.34a but I don't read nothing about "repairs". It's reasonable performance a test pressure with the procedure for a new valve?
RE: Pressure Test for a Control Valve Repair Body
I would recommend you to go to this website:-
www.controleng.com
Hope It will help you!
