Difference between generalized and localized cracking
The question may be stupid, but I cannot find any clear definition of both generalized and localized cracking.
Does anybody know the difference, preferably in aircraft structures?
Thank you.
RE: Difference between generalized and localized cracking
localised cracking is an isolated crack, say a crack at a hole.  typically initiated by a specific (individual) flaw.
generalised cracking is several cracks reasonably close together, or multi-site damage.  typically initiated by fatiguing many small (minor) flaws that are replicated at many sites (ie typical manufacturing quality).
Thank you rb1957!
May I say that cracks found in a joint or fitting (where we have significant load transfer from  fastener to fastener) are localized, while cracks found at a wing skin panel spanwise splice (load transfer is almost zero) are generalized in terms of the wing fatigue life?
Or you think my interpretation is irrelevant?
i wouldn't connect the terms with load transfer.  splices with load transfer are just as likely to develop generalised fatigue cracking as those without load transfer.
