O-Ring Face Seal
O-Ring Face Seal
I'm designing a simple face seal and need to control the ID of the groove (external pressure). I have 4 lines and 4 radii and would like to combine it with one dimension to control the ID circumference. How do I do this? I was able to combine the geometry by making a "Make Path" (screen grab & RMB), but how do I dimension it once it's joined.
Macduff ![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 5.0
Dell 390 XP Pro SP 2
Intel 2 Duo Core, 2GB RAM
nVida Quadro FX 3450 512 MB
RE: O-Ring Face Seal
I just started looking into that, but can't get it to work.
This is what I got:
( "D2@Sketch1" + "D2@Sketch1" ) * 4 =
I get "Equation Entered is Invaild". I'm kinda a novice at this function
Also, how do I dimension radius and get its arc length?
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Dell 490 XP Pro SP 2
For a full circle, just do the math C=πØ.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Colin Fitzpatrick
DimensionToControl = ( "D2@Sketch1" + "D2@Sketch1" ) * 4
FAQ559-590: Rename sketch dimensions used in equations
Always rename dimensions used on both sides of the equation.
Dimension your groove so that the entire shape is constrained to itself and the position (ID) is the final constrained needed to fully constrain.
Now that I kinda have that out out the way...I would like to control the overall input value (total length of the shape) and have the 4 radii remain constant (designed value a known) and have the 4 lines adjust in length, based on changing the overall length.
Are ya with me?
I'll try and upload a image.
Colin Fitzpatrick
Colin Fitzpatrick
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
Equation;
VerticalLength=(Perimeter-(ArcLength*4+HorizLength*2)/2
arc length for 90° arc = pi*r/2
This way you can just control radius of corner
You need parentheses:
OAL = 4*(D1 + D2)
with D2=.228 and D1=3 result is 12.912, your perimeter result is wrong the way you have it.
Change your arc length back to a radius and try this:
OAL = 12.228
D1 = (OAL - 4 * (pi*radius/2) ) / 4
I need the arc length to be adding to the total length. the radius size is different than the arc length. this is needed when I size the id of the oring.
Colin Fitzpatrick
Chris
AutoCAD 06
ctopher's blog
AWESOME! How many stars can I give you!
I can now plug in my overall length and even adjust the radii and everything adjusts. As they say in the Guinness TV commercials; Brilliant!
Hey, can you check the attachment?
Thank you so much!
Colin
Colin Fitzpatrick
You can double-check results by selecting all the curves and using the measure tool to get total length (length also shown at bottom of SW window).
Best,
Colin
Colin Fitzpatrick
