Batch Open Save Command File
I need help developing an open save command file for MicroStation. We have macros for that update our titleblock information via Excel everytime we open a sheet file. So when we update the spreadsheet each drawing needs to be opened (the macro will automatically run) and then saved for the titleblock to be updated.
In MicroStation under the Utilities pulldown menu there is a Batch Process command. With this command you can add the files that you want to perform a batch process with. In my case it would be the sheet files. But I'm having trouble developing the command file. Can anyone help me with this?
Rob
Rob
RE: Batch Open Save Command File
However you may find the following script useful
Fit view extended;filedesign; close design
the first part centres the design to the screen
the second part saves the settings and changes made
the last part saves thedgn and closes the file.
Thanks for your help. The script you provided worked, but I modified the last command for my own preference. I also had to enable Automatically Save Design under the Workspace>Preferences>Operation menu.
Thanks again!
