apply heat on elements surface
hi all forum,
any idea how could i apply heat on the elements surface, say i have an I-steel beam, i want to apply heat on the bottom surface of the bottom flange only, as in reality the bottom part of the beam was subjected to fire. I created the I-section model by using shell element. I notice that i can only apply heat on the nodes of the elements, but not the elements itself. please help. thanks.
RE: apply heat on elements surface
corus
