Obtaining the max value
I am trying to obtain the max value of FX for example for an element BEAM188, from solution with 2000 steps...
I am using ETABLE. Can somebody tell me how to find the max value, and print it, using a macro?
Thank you all
RE: Obtaining the max value
the best way is not the ETABLE but the ESOL command. See next code.
CODE
! Enter Time post processor
/post26
! Read Axial Force FX at node I for Element elno
esol,2,elno,,smisc,1
! Get the maximum Axial Force
*dim,elemfx,array,2000 ! Array definition no more necessary since Ansys v11
vget,elemfx,2
*vscfun,fxmax,max,elemfx
Alex
Thanks a lot mihaiupb,
that really helps!
The problem is it works only if I write the element number. Do you know how can i make it for more than one element?
Can you explain in more detail what you want do do?
Do you want to:
1) get the ONE maximum FX of all elements over all steps ,
2) get N maximum values for EACH element over all steps,
3) get N maximum values for a GROUP of elements over all steps
Alex
4) get the One maximum FX of all elements over all steps...
its a steel frame with columns and beam, and i need the max in the columns and in the beams
Plamen
Then you will have to do a loop over all elements:
CODE
/post26
fmaxmax=0
esel,s,enam,,188
elno=elnext(0)
*dowhile,elno
 vget,elemfx,2
 *vabs,,1
 fmaxmax=(fmax>fmaxmax) ! the maximum of FX over all elements
 elno=elnext(elno)
*enddo
Thank you very much, you helped me a lot
Plamen
