Cold-Reforming of UNS 39274 (duplex) Tubes
Hello to all,
we have a multitube heat exchanger (minimum center to center diameter: 14") with tube bundle according to UNS 39274 (superduplex) cold formed and solution annealing(U-bends and 12"). The tubesheet layout is square pitch (1") and the U-Bends have been formed according to triangular layout (15/16"). Due to long delivery date of new forged tubesheet (UNS 39750) or new tubes, we would like to repair the U-Bends safely. Herebelow you have sime more detailed information:
- Maximum radial displacement: 1.5" (opening and closing the bend).
- Total length oh tube bundle: 240"
- Distance between the U-Bends tangent line and the first baffle: 1"
- BWG: 16
- Tube OD: 3/4"
Our major concern is the first baffle because this is the most deformed region because the radial displacement of the tube is 1.5" in 1" distance (i.e, 56ยบ). Our idea is to perform necesssary and realistic non-destructive/destructive to assure the integrity of the tube: For example, we have proposed the following:
- Thickness, ovality, visual inspection, diameters, eddy current testing,. Which is your opinion?
From a metallurgical point of view, we could have any problem with the tube based on the above information. Would be necessary to perform again the solution annealing? Would you recommend to perform any non-destructive examination or any other?
Thanks for your support and awaiting for your reply.
Peter
- BWG: 16
- Tube OD: 3/4"
Peter
RE: Cold-Reforming of UNS 39274 (duplex) Tubes
If you had asked me I would have suggested that you not anneal the bends in the first place.
Plymouth Tube
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
