Draining firewater
Draining firewater
Draining firewater
When calculating the capacity for a drain of deluge water i have seen a recommendation in an engineering practice to use a formula for vertical liquid filled pipes.
But if the drain system is in fact not vertical (the standard is for offshore but the project in question is a FPSO) but contains sections with 1:50 slope should i then instead use the capacity for vertical non filled pipes based on Froud no. (about 1:10 of the capacity)? There is a total head difference but as i said - vertical sections and sloped sections.
Best regards
Morten
RE: Draining firewater
1 vertical to 50 horizontal?
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
yes - but  mix allway though with a min 1:50 slope and no deadlegs (frost)
Best regards
Morten
