Complete joint penetration
I need to make a baseplate for a machine, but my customer is requesting me complete penetration joints as part of the requirments.
my concer is the plate thikness (32mm), I am not sure if it is allowable to do such a job on this kind of material.
in other hand I have a perpendicular union (T) and I do not know how to prepare the material.
RE: Complete joint penetration
There is pressure equipment made of 200 mm and thicker plate, welded full penetration as per the code requirements. 32 mm plate is not categorized as special material;- it however, depends on the material (I only assume that you are using carbon steel material). It is also true that welding full pen 32 mm plate requires considerable effort/costs and no additional gain, compared with a partial penetration, if no corrosion problems are present. Also, if the T union seems to be in the other hand, perhaps you could change hands. As for plate's welding preparation, you could make a double V (V on both sides) and weld slowly, low heat input in the root weld, then blast it with FCAW.
cheers,
gr2vessels
