Broadcasting Digital Transmisor Heat Dissipation
Dear sirs:
I am Mechanical Engineer working in Air Conditioning project.
In order to conclude a preliminar cooling looad estimation, for a room containing a 100 KVA digital broadcasting transmissor, I need estimate how much heat that kind of equipment realease to the surrounding space.
Could you give me an approximate heat release quanty?
Thank you,
schola
Thank you,
schola
RE: Broadcasting Digital Transmisor Heat Dissipation
Keith Cress
schola
Also, there may be failure modes to be addressed.
You could probably look it up on the specification for the system. If not, then contact the OEM (Nautel or whomever).
