Low hardness at weldment and HAZ
What should we do if we find low hardness of fired heater tube? I have no information during fabrication. This might be occured several years ago without thickness measurement.
For further comment, please advise me about documents to study about replica in detail.
RE: Low hardness at weldment and HAZ
I did not see any detrimental effect in past operation. This is the first time that I check hardness at such location.
The other case is overheating or burning of this steel. If this is so - thermal heating wont restore mechanical properties.
To find out the reason I recomend you to make microstructure testing.
