SWMM run anomaly
SWMM run anomaly
I've just started using EPASWMM5 as opposed to the proprietary versions. I can't seem to figure out how to make it run. That is, I can click various sequences of save, run, and map animator and every now and then it will run and produce reasonable results. The times in between, it'll say it ran successfully, but I'll have zero flow for several attempts. Is there a patch, am I doing something wrong, or should I just reinstall it?
RE: SWMM run anomaly
I've never heard/read of this problem before. It may be an installation issue, but that would be fairly rare due to the compact code architecture.
You might try posting the *.inp file for review and check out the post "SWMM5 EXAMPLE" (thread162-202765: SWMM5 EXAMPLE).
http://www
tsgrue: site engineering, stormwater
management, landscape design, ecosystem
rehabilitation, mathematical simulation
http://hhwq.blogspot.com
Is there a way to plot the max HGL without scrolling through to a specific time? Although I guess in a large system, the max HGL would actually occur at different times depending on which conduit you were looking at.
