MODEL LIVING HINGE
MODEL LIVING HINGE
Using Wildfire 2.0,I have modeled a plastic part with a body and lid.They are connected by a living hinge,so I want to make a family table of the part both "opened" and "closed".Can soemone give me some helpful tips?
RE: MODEL LIVING HINGE
ht
Any luck with the living hinge design. I too am using Wildfire 2.0 and haven't had any luck creating a living hinge with family table.
- Spinal Bend ? Is this in the Standard ProE module or are you using Surfacing? I don't have Surfacing so I can't check. If in the standard module - is it a Warp feature? Spine tool? or Bend tool?
check under;
Insert>Advanced> then you should have a number of other features including Spinal Bend
you may have to have in your config.pro
allow_anatomic_features yes
..but not sure for spinal bend
