Watermain under road with insificient cover
I have a watermain that has to pass over a very large storm pipe. The thermal cover will be 3'. 5' of cover is required in our area. Should pre-insulated pipe be used or should styrofoam sheets be used above the pipe? Both?
PG
PG
RE: Watermain under road with insificient cover
good luck
