Unfold a sheet metal cylinder
I'm fairly new to SolidWorks and I'd like to know what's the best way to create a hollow sheet metal cylinder and unfold it to a flat pattern. I can create the cylinder I just don't know how to unfold it. Any help would be greatly appreciated. Thanks
RE: Unfold a sheet metal cylinder
The cylinder can not be 360°.  It needs to have a break, ever so small.
Make the partial cylinder, then use "Insert --> Sheet Metal --> Bends" to turn it into a sheet metal part.  Select an edge to be the fixed portion.  You can then use Fold and Unfold.  You will need to select an edge instead of a face for your "fixed face".
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Thanks Tick, that's just what I needed. Much appreciated.
What about a cone?
Thank you for your time and help,
Glenn
thank you
