Dirty water tank not getting filtered?!
Im puzzled at the filtration system in place. The tank capacity is around 10,000 U.S gallons. There is a 1/2 hp pump with a 1 1/2 inlet and outlet, drawing water from the bottom of this tank.(7ft head)To complicate matters, this is then going through a single stage, 5 micron filter and then returns to the tank through 70ft of 1 1/2 pipe. Im a complete novice at this kind of thing but my numbers tell me the rating on this pump is incorrect. p.s there is a gauge on the outlet side reading 10-20 psi. Im trying to research this more but any assistance would be appreciated
RE: Dirty water tank not getting filtered?!
How far from tank to pump and pump to filter?
What is the pump height in relation to the tank? Is the pump at the same bottom of the tank elevation, higher or lower? How many feet?
How high is the highest point on the return line (in relation to the pump, as in feet higher than the pump elevation?
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
For that 25 differential pressure (loss) at the filter, plus another 10 psi or so for pipe losses, you'd need at the least a 1 HP with very good pump efficiency. I'd suggest a minimum of 1.25 HP (allowing for somewhat lower efficiency).
While you're at it, be sure the pump has a rated differential head of at least 80 feet at that flowrate of 36 gpm, which indicates a discharge pressure in the range of 40 absolute minimum to 50 psig will be needed.
