Mandrel Grip force Calc
Good evening all, I am in the process of designing an insert type mandrel (My first) and require what I hope is a simple calc.
The mandrel had a body Dia OD 60mm, with five inserts.  These inserts have a 7 deg angle base which matched to a horizontal wedge plunger with the matching angle.
I want to calculate the outward force of the insert, when I know the given horizontal pullback from my hydraulic cylinder.  I can then change the force of the cylinder to get the required clamping force.
I've attached a piccy if it helps.
Any help would be greatly appreciated.
Thanks in advance,
Mark
RE: Mandrel Grip force Calc
Thank you for yor help, very simple really.
Cheers
Mark
