Rotating while extruding "twist/screw"
Hi all, this is my first time posting on the forum. I have been using NX for about 4 years and came across a problem I cannot model.
To simplify the problem, I will use a block. I am trying to extrude the block along an axis that is in the center of the block, while having the block rotate about that axis 2 full rotations over 4 inches. So it would be one full rotation every 2 inches.
For the life of me, I cannot figure out how to rotate the block while extruding it. Please help!
Thanks you,
Brian
RE: Rotating while extruding "twist/screw"
By 'Block', I assume you mean a rectangular profile/sketch, correct?
Is, draw your profile/sketch and then create a 4 inch long Line normal to and centered on your profile/sketch, to represent the axis of your 'twisted-soild' that you want as a result.  Now select Insert -> Sweep -> Swept... and select the 4 inch long Line as your single Guide and the profile/sketch as your single Section, using for your Orientation Method a Rational Law suing the Linear Law Type setting the Start and End Values to 0 and 720 and hit OK.  Your result should look like the attached image.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
John,
Some of the edges don't quite line up. Is the axis not in the center of the block or is something else going on there?
John, Thank you very much for the fast help. Your explanation was exactly what I was looking for. I never experimented with the different law functions before and that did the trick.
Have a great week!
Brian
John,
I do have an additional question. I got it to rotate and am playing with all the preferences, but can't get it to rotate the opposite direction. Any help would be great.
Thanks!
Brian
Have a great week!
Let's hope so!
The first round of customer beta-testing of NX 6 started this morning and will continue for the next several weeks.
John R. Baker, P.E.
NX Design
Cypress, CA
I got it, as its simple to add a negative sign. Lack of thinking on my part. Thanks again and have a great week.
Brian
