compressor control
compressor control
i have a case of installing new booster compression station on existing pipeline (centifugal compressor gas turbine).
the pieline lenghth downstream comp. is 230km and is delivered to gas complex .
is the back pressure control valve is essential the as designer says that discharge compressore back pressure control valve is not recommended .
RE: compressor control
