2D layout for 3D design, generative problem
I created a layout in 2D layout for 3D design but, none of the dimensions are staying generative and when I update the 3D part the dimensions just stay where they were with the same measurement. I then go back and redimension the whole drawing. Could someone please explain if there is a way to changed the dimensions to generative or update the dimensions without edrawings?
Thank you.
Thank you.
RE: 2D layout for 3D design, generative problem
Derek
DBezaire - Driving dimensions works also in 2D to 3D layout.
The nature of your model update is also important, if it's editing then there shouldn't be any issues but if feature adding then it could be a drawing issue
