Error while trying to restart the analysis
When i try to restart my analysis, i get this error message and i don;t understand why.
***ERROR: Features such as new nodes/elements, IMPORT, SYMMETRIC MODEL
GENERATION, MAP SOLUTION are detected in a continuation analysis
where the original model is defined in terms of an assembly of part
instances. This is not allowed.
Note that i didn't change anything from the original input file. Just modified something in a subsequant step and i don't believe that is the reson.
RE: Error while trying to restart the analysis
Any change made in the Keyword will not be considered in the Restart>
Try add this in the first step and re-run the inital FEA.
*model change, Activate
Hope that should slove your problem
