Version Converter
Version Converter
I am getting pretty fed up with Mathcad and the rude way they treat their users. Have used Mathcad for many years, but a number of my legacy programs from before no longer work with new versions of Mathcad. So for this reason I am not eager to spend good money every year just to get the latest version.
My problem is that, even though I recently upgraded to Mathcad 13, I just got a file in Mathcad 14 that my version would not open. I assume these jerks just write something in the file header to disable earlier versions from using the newer files. So how do I hack in, or use some sort of translator, to be able to down-version new files that someone sends me and read them in Mathcad 13? Is there some freeware around to do this.
RE: Version Converter
I used CompareIt to compare the files. There are other text comparison programs that should work too.
If the v14 file is in compressed mode then you may be out of luck. Save in xml text mode if you want to make comparing easier.
There are subtle changes in the XML between the versions.
One thing that annoys me about XML in general is the way they have these alledged URLs for the XML type (inside the XML e.g. xmlns:ws="http://schemas.mathsoft.com/worksheet30") then don't have a file there that tells you what the format means!
Philip
TTFN
I am just saying that for future reference, even say 3 years from now, I might want to take a mathcad 16 file and still read it in! The very few features they add each year and bang you $300+ for them are probably not going to be used in the newer files anyway, so except for a secret header somewhere in the file, an old version of mathcad should work just fine at reading them.
TTFN
Most are still welded to V11, or V2001, and some to V6! You won't be alone in wishing PTC well
regards,
Philip
