SKM ANSI fault study multiplier
Hi everyone,
I'm conducting an ANSI (A_Fault) study using SKM Power Tools and have a question about the multiplier used for the crest kA it "spits out."
I have figured out from the ANSI/IEEE standards that the multiplier for momentary current (i.e. 1.6) is for the half-cycle current, but where does the crest current multiplier (i.e. 2.7) come from?
This value of current seems like it would be very siginificant in the application of breakers/fuses since it's larger in magnitude than the momentary value.
Any advice would be appreiciated, thanks.
Richard Byrne.
Richard Byrne.
RE: SKM ANSI fault study multiplier
Just as in the calculation of the multiplier for the rms case, the peak (crest) multiplier implicitly assumes a fault point X/R ratio of 25 and that the maximum value occurs at 0.5 cycles into the fault current cycle.
Any confirmation/contradication is appreiciated, but this is the thinking I'll use for now.
Cheers, Richard.
I could attach an excel spreadsheet ( if I knew how ) to show that if I"k = 1, and X/R = 15, then i peak = 2.56 and I asym rms = 1.52
The 'first cycle asymmetrical rating' is the rms of the current over the first 0.5 cycle following fault inception.
The attached spreadsheet shows that if I"k = 1, and X/R = 15, then i peak (crest) = 2.56 and I asym rms = 1.52
I asym rms is also called "close and latch" or "making" capability, previously known as "momentary" capability.
