27 feet high Brick (Clay) masonry wall
Wind load will be 20 psf and Reinforced beam are resting at every 12 feet with 63 kips reaction. Any tips?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
27 feet high Brick (Clay) masonry wall27 feet high Brick (Clay) masonry wall(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: 27 feet high Brick (Clay) masonry wall
Or make the wall thick enough to meet code requirements of ACI 530.
What are the details of the wall construction? - thickness, number of wythes, reinforcement?
If it is not in place, a reinforced block wall with a brick veneer would be more econoomical and have the same appearance. Try to distribute the beam loads throughout the length of the wall, rather than deal with vertical "columns".
More details would help give better suggestions.
Dick
If you need a brick exposure on one side and can tolerate another surface on the other side, a reinforced block bearing wall with a brick exposure will be the most economical, since you can pack a lot more steel into the wall for strength purposes.
I am sure you realize your problem is with the wall height and distributing the column loads. If the wall was only 8' high, you could go 20+ stories with just a 6" block wall.
I need to use brick masonry for some reason.
LL on roof = 20 psf.
Wind load on side walls = 20 psf
Building foot print 50' x 200 '
so RCC beams are spanning 50'. Hence reaction becomes 63 kips factored.
Building is not built yet. But walls have to be brick masonry and slab RCC.
Single storey building.27 feet high to give 24 feet clearance.
3 feet deep concrete beams.
Can 12" thick reinforced brick masonry be ok. Use #8 @ 12 " c/c and o.c.
Thanks.
Note that we cannot answer your question about a specific size and spacing.
If you have to match an existing brick (probably a typical modular sized brick), your wall construction becomes limited to load bearing brick wythes on either side of a grouted cell. This gives you a small "d" (about 5."), which is a problem with the wall height. This type of wall also imposes constructability restraints, tight specifications on the grouting and inspection, plus a cost burden.
If you are allowed to use an oversized engineered brick (limited selection), you could design a double wythe bonded reinforced brick wall that could have a greater "d" distance.
Some preliminary calculations could help you make some decisions on the practicality of the diferent wall possibilities. After that, you can address the actual structural design, load distribution, details and the construction challenges.
