Finding out what the customer REALLY wants
I'm involved with a project where one of the common (mis)conceptions is that the customer "doesn't know what they want." I was just wondering if anyone else out there has learned this to be the case, where in initial discussion, the customer appeared to want one thing, but upon delivery, they really wanted something else. Have any of you learned any tricks of the trade in trying to get to the root of customer needs up front? And what tips you off to this, (i.e. how can you tell when the customer really doesn't know)? Any resources you could point me to for such tactics?
Aaron A. Spearin
ASQ CSSBB
Engineering Six-S'$
www.Engineering6ss.com
"The only constant in life is change." -Bruce Lee
RE: Finding out what the customer REALLY wants
This is why there are product specs and contracts.
The best way to test something is to squeeze it, slowly, until it breaks!
Aaron A. Spearin
ASQ CSSBB
Engineering Six-S'$
I used to have a client with a habit of changing his mind. One time, we was surprised when I presented an invoice. He paid it, but I did not hear from him again.
Read the book "Nuts!" about Southwest Airlines. They also beleive the customer is not always right.
Don Phillips
http://worthingtonengineering.com
Business is business.
TygerDawg
Blue Technik LLC
Advanced Robotics & Automation Engineering
www.bluetechnik.com
Perhaps take these projects on incrementally. First phase is to take customer's fuzzy vision and come up with multiple clearer proposals. When the customer accepts a clear proposal, continue further.
We see a lot of engineers providing the owner with different ways to do things, and then expect the owner to make a decision (chose from one of the options presented). It's like a doctor telling you "do you ahve any questions?" No, I don't have questions, I want you Mr. Expert to to tell me what I shpould do, because I am paying you for your "EXPERTISE".
If the owner knew what to do, he wouldn't need an engineer.
My advice is: make three alternates with all their pros and cons and cost estimates, time line, down time,etc..., and present the owner with the options AND make a rcommendation on how he should proceed.
Don't be afraid to make a decision for the owner, if you are going outside of his scope, then he will tell you. But I guarrantee you that if you put your money where you mouth is, your client will respect you for it.
Look at it this way: consider it as your money, how would you spend it? this approach has always cleared the air for me.
-b
You are exactly right, and I should have stated it more clearly. I am an engineer working on a project to basically improve on the marketing/sales ability to extract such information. I suspect consultants in the biz face many of the same obstacles as marketing/sales do when dealing with the customer, especially if you are independently trying to market your service. Any tricks of this trade are helpful. From what I've been reading, it really is a matter of deep listening and redundantly verifying customer needs.
Aaron A. Spearin
ASQ CSSBB
Engineering Six-S'$
A persistent problem with this is that customers may write something so thorough that he/she can't afford to pay for it or that there's no room for "stuff that comes up."
Specmanship is an art that shouldn't be left to marketing folk.
When all else fails, ask, ask, ask and clarify. Unless you're really in a closed bid process, that telephone is your best friend.
Regards, MEF
DTUCK
www.mfgsols.com
The first Level is just your typical sales person, no engineering background, and basically he will sell product to people who basically know the serial number of the product they want.
Level 2- If the customer does not know exactly what they want, but are familiar with what “we do” they are passed to the Application “Engineer.” (Someone how has a degree in engineering… but is doing sales.) Normally this is where it stops and he hopefully can clear up any problem.
Level- 3 However is this is still any confusion; the person is passed on to a design engineer (me), which gets handed notes form everyone else. I often ask them enough questions about what they want to do, so I have a pretty good idea what will be best for their application. If they don’t seem to be picturing what happening is have them visit out web page so they have a better idea of what can be done. Normally the person wants something not standard. So I come up with a concept drawing and quote…. If they don’t like it I work up something else or then the fun starts…
Only major Con- This works well as long as the Applications engineer knows his limits and when to pass work on. I have seen numerous projects screwed up because the application engineer through he would try something.
Other con, you need the staffing and demand for product.
Major Pro – Major/Long term customers know which “level” to call right away for projects, so the process becomes pretty direct.
Aaron A. Spearin
ASQ CSSBB
Engineering Six-S'$
To some extent it can be summed up by that design 101 gem "know your requirement".
If the customer can't explicitly define his requirement then you need to formulate it and have him agree to it before starting any real work.
Where this needs technical input get engineering involved in helping prepare the SOW/Spec/quote etc. Perhaps adding an Engineering sign-off to all quotes if this isn't too cumbersome.
That way even if sales haven't asked up front Engineering get a chance to shut the barn door before the horse has bolted.
One potentially bad thing is that this will typically require more effort up front before you're guaranteed getting paid for it. This cost needs to be allowed for.
You may also need to be willing to either no-bid when the up front effort isn't justified by the risk/benefit. Some places I know will rather than no-bid just put in an extremely high bid to deliberately lose. Not sure I fully comprehend the logic but it's something to do with customer perceptions.
Different industry so not directly applicable but at my last place for one part of the business any job that had significant Engineering input we actually did most of the costing and bid prep. The other side had their bids prepared by sales/marketing types with limited technical knowledge. I'll let you guess which side made money on pretty much every contract and which lost money on pretty much every contract.
KENAT, probably the least qualified checker you'll ever meet...
The "three level" method used here, is also dynamic for how the pricing works out.
The first level deals with, "List Price" products which are basically out of the box.
By the third level, it is normally "Bid" and often a lot of the engineering is done before we even "have" the project (which is hard to avoid). And the customer gets full drawings and has to sign before anything else is done, with a statement that they understand the implementation of the design... bla bla
This insures we don’t loose money because a sales man promised someone the sun, there is the option for an engineer and step in and say...the placement of that bolt is going to cost $10k more where you want it... do it this way.
It’s not perfect because some projects have and will slip through... but they are normally caught by the production controller... and then someone gets a talkin’ to.
