SECTIONED PART DISAPPEARING WHEN EDITING
While an assembly is in a sectioned view and I go to edit a part, when I choose a face and open a sketch, the part being edited disappears. If I exit the sketch the part reappears. Any suggestions as to why this happens and how to keep it from happening? Thanks
RE: SECTIONED PART DISAPPEARING WHEN EDITING
What are you using?
The part can also be displayed correctly by using the option to "Open Part" from within an assembly. Using a section view here does not affect the part, and it is possible to edit the part as would be done normally.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Jeff... yes I realize the two suggestions you offered... I'd like to edit the part in the assembly so I can use the other components as a guide to sketch around when editing the part that (unfortunately) keeps disappearing.
But thanks again for the help.
John
