ESC simulation problem.
Hi everybody,
I need your help !
I simulate a pipe with a flow of water with a velocity inside it.
I want to simulate a fan at the entrance of the pipe which represents a fully developed profile (results of Navier-Stokes equations, the velocities are parabolic profiles) yet and that all along the tube, which can be obtain normally after a lengh of 50 diameter.
my goal is to limit the duration of the calculation with a pipe not too long !
thank you for your help.
