condensing gasoline vapor
I have to drop the temp of a fuel vapor stream (continuous)to condense the vapor. Input temperature of the stream will be about 4 deg C, modestly dehumidified. Flow rate is variable, but 30-40 liters/minute max. What size compressor and how should I configure this unit? (apologies for my naivity, I have run down the cyber hallway to talk to you ME guys.
thanks for the help.
RE: condensing gasoline vapor
Thanks for responding. It is an important experiment and we need to have an expert in on it.
thanks again
Alternate designs would be using a blower to put the vapor through a carbon bed absorption unit which would require two beds so that you can shut down and regenerate one.
You could also look at some sort of lean oil stripping or such unit.
A number of smaller refrigeration packagers should be able to help you, but be careful that they have the experience and can actually do the design work. You don't want a Mom and Pop operation out of the garage on alternate weekends.
Ken
Ken
KE5DFR
doug
At this moment I have a device that will get me to -40C, but the exchange rate cant be too high.
thanks again.
Another company to look for for vapour recovery would be Coolsorption (Aker Kværner group):
http://www.coolsorption.dk/
Best regards
Morten
doug
