Camshaft spin balancing
So what are the opinions on this?
Some have reported some kind of performance improvement.
But is there really any merit to it? Or is any reported improvement due to something else that is not readily apparent?
RE: Camshaft spin balancing
This all reduces the impact of being out of balance.
Also valve spring pressures set up their own out of balance forces.
A small block Chevy V8 is out of balance by design.
I never analysed anything else, I expect in line and horizontal engines of 2 or more cylinders should be in balance by design, and any out of balance due to manufacturing tolerances would be very small.
All in all I see very little potential for gain by counter weighting a V layout cam and even less by balancing an in line or horizontal engine.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
http://speedtalk.com/forum/viewtopic.php?t=2488
Cheers
I don't know anything but the people that do.
Just wanted to see what you folks would say about it.
